Obrigado irmão, me passa seu skype por MP, obrigado. Abraço.
Blz,
Mandei o contato lá!
Vamos ver como resolver.... E assim que encontrar a resposta... Detalharemos a mesma aqui!
Sent from my iPhone using Tapatalk
Executa esse comando pelo SSH e informe o resultado!
crontab-l
0 6 * * * /usr/local/cpanel/scripts/exim_tidydb > /dev/null 2>&1
30 5 * * * /usr/local/cpanel/scripts/optimize_eximstats > /dev/null 2>&1
2,58 * * * * /usr/local/bandmin/bandmin
0 0 * * * /usr/local/bandmin/ipaddrmap
12 22 * * * /usr/local/cpanel/scripts/upcp --cron
0 1 * * * /usr/local/cpanel/scripts/cpbackup
0 2 * * * /usr/local/cpanel/bin/backup
35 * * * * /usr/bin/test -x /usr/local/cpanel/bin/tail-check && /usr/local/cpanel/bin/tail-check
45 */4 * * * /usr/bin/test -x /usr/local/cpanel/scripts/update_mailman_cache && /usr/local/cpanel/scripts/update_mailman_cache
30 */4 * * * /usr/bin/test -x /usr/local/cpanel/scripts/update_db_cache && /usr/local/cpanel/scripts/update_db_cache
45 */8 * * * /usr/bin/test -x /usr/local/cpanel/bin/optimizefs && /usr/local/cpanel/bin/optimizefs
30 */2 * * * /usr/local/cpanel/bin/mysqluserstore >/dev/null 2>&1
15 */2 * * * /usr/local/cpanel/bin/dbindex >/dev/null 2>&1
15 */6 * * * /usr/local/cpanel/scripts/autorepair recoverymgmt >/dev/null 2>&1
*/5 * * * * /usr/local/cpanel/bin/dcpumon >/dev/null 2>&1
13 21 * * * /usr/local/cpanel/whostmgr/docroot/cgi/cpaddons_report.pl --notify
5,20,35,50 * * * * /usr/local/cpanel/whostmgr/bin/dnsqueue > /dev/null 2>&1
*/1 * * * * /usr/local/cpanel/3rdparty/bin/php /usr/local/cpanel/whostmgr/docroot/whmsonic/tools/playlist_auto.php >/dev/null 2>&1
*/1 * * * * /usr/local/cpanel/3rdparty/bin/php /usr/local/cpanel/whostmgr/docroot/whmsonic/tools/bitrate_control.php >/dev/null 2>&1
* * * * * /usr/local/cpanel/3rdparty/bin/php /usr/local/cpanel/whostmgr/docroot/whmsonic/tools/bw_control.php >/dev/null 2>&1
Postado.
Obrigado, a todo problema resolvido, era a instalação de 2 RPM que eu tinha alterado... Re-instalei e resolvi o problema.
Agradeço a todos que responderam aqui.
Atenciosamente,
Bruno de Sá
