Amigos, urgente, preciso montar o disco no SYS,
eu entrei em modo RECUE e não consigo colocar o disco padrao para entrar,
alem disso, do nada do whm nao consegue também mais acessar nem ssh nem nada,
so em modo RECUE,
acho que o disco encheu, preciso voltar tudo no ar, me ajudem...
# PRINT dos discos que tenho, e qual comando uso para montar?
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: E1C80119-B405-438C-99DA-6589DA1283C4
Device        Start        End    Sectors  Size Type
/dev/sda1      2048    8390655    8388608    4G Linux RAID
/dev/sda2   8390656   16779263    8388608    4G Linux RAID
/dev/sda3  16779264 3907022847 3890243584  1.8T Linux RAID
Disk /dev/sdb: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: gpt
Disk identifier: 4559B528-5F5B-4DC7-BEB3-B4D13B135315
/dev/sdb1      2048    8390655    8388608    4G Linux RAID
/dev/sdb2   8390656   16779263    8388608    4G Linux RAID
/dev/sdb3  16779264 3907022847 3890243584  1.8T Linux RAID
Disk /dev/md3: 1.8 TiB, 1991804649472 bytes, 3890243456 sectors
Disk /dev/md2: 4 GiB, 4294901760 bytes, 8388480 sectors
Disk /dev/md1: 4 GiB, 4294901760 bytes, 8388480 sectors
Disklabel type: dos
Disk identifier: 0x20ac7dda
Device     Boot      Start        End    Sectors   Size Id Type
/dev/md1p1 ?    3224498923 3657370551  432871629 206.4G  7 HPFS/NTFS/exFAT
/dev/md1p2 ?    3272020941 5225480974 1953460034 931.5G 16 Hidden FAT16
/dev/md1p3 ?             0          0          0     0B 6f unknown
/dev/md1p4        50200576  974536369  924335794 440.8G  0 Empty
Partition table entries are not in disk order.
Disk /dev/mapper/VG_XenStorage--3502f935--8933--15aa--3a85--584c4d714803-MGT: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mapper/VG_XenStorage--3502f935--8933--15aa--3a85--584c4d714803-ISORepository: 10 GiB, 10737418240 bytes, 20971520 sectors
Disk /dev/mapper/VG_XenStorage--3502f935--8933--15aa--3a85--584c4d714803-VHD--427a966b--6ddc--40d1--a47a--0551ab814805: 501 GiB, 537927876608 bytes, 1050640384 sectors
root@rescue:~#
Fala @JuniorZ
Tive um problema parecido no começo do ano em relação ao kernel. Mexi em uma configuração, reiniciei o servidor e nunca mais o servidor iniciou, apenas no modo de recuperação.
Depois de várias horas desesperado, aprendi a fazer isto. Segue abaixo:
Por quê e quando usar o modo de recuperação?
Para colocar o servidor em modo de recuperação, rodei o seguinte comando:
#mount /dev/sda3 /mnt
chroot /mnt/
Porém, após rodar o comando, eu recebi a seguinte mensagem de erro:
Last Login: Thu Oct 8 13:33:01 2015 from xxx xxx xxx xx
root @ server: ~ # mount /dev/sda3 /mnt
mount: unknown filesystem type 'linux_raid_member'
root @ server: ~ #
O erro acima indica que eu devo começar a montagem pelo Software Raid.
Então, após várias pesquisas, eu encontrei essa dica aqui: https://mauricionh.wordpress.com/2013/05/08/montar-particao-com-soft-raid-linux/
Só que, como essa era minha primeira vez botando o servidor no modo de recuperação, então, por via de dúvidas, eu não segui o tutorial e acabei entrando em contato com o suporte do Data Center novamente e eles me recomendaram seguir os seguintes passos:
Alguns dos comandos abaixo irão abrir como se fosse o editor de texto, mas não há necessidade de fazer edição, apenas descarte e rode o comando: CTRL + C para sair do modo de edição e rodar o próximo comando.
Começando pelo Raid
# mdadm --assemble --scan
A resposta do comando será:
mdadm: /dev/md/0 has been started with 2 drives.
mdadm: /dev/md/1 has been started with 2 drives.
Checando o Raid:
# cat /proc/mdstat
Personalities : [raid1] [raid0] [raid6] [raid5] [raid4]
md1 : active raid1 sda3[0] sdb3[1]
1951809344 blocks super 1.1 [2/2] [UU]
bitmap: 0/15 pages [0KB], 65536KB chunk
md0 : active raid1 sda1[0] sdb1[1]
524224 blocks super 1.0 [2/2] [UU]
Agora vamos montar as partições relacionadas
# mount /dev/md1 /mnt/
# mount /dev/md0 /mnt/boot/
# mount -o bind /dev /mnt/dev
# mount -o bind /proc/ /mnt/proc/
# mount -o bind /sys /mnt/sys
Alterar ambiente:
# chroot /mnt
Veja os seus arqivos:
# ls -la
Obs: este tutorial não foi feito por mim, mas foi de extrema ajuda que guardei a sete chaves comigo rsrs
Ah, se julgar necessário, a própria OVH tem um tutorial explicando como fazer isto (http://guias.ovh.pt/Moderescue#link5) - qualquer coisa, dá uma olhada.
Espero ter ajudado :)
