@xandehenrique
Pelo que pue observar u a instalação foi mal feita ou tentou atualizar o phpmyadmin.
Tente alterar o seu arquivo config.inc.php (usr/local/apache/htdocs/phpMyAdmin/ ) substituindo o conteúdo do mesmo por este. Lembre-se faça backup do seu arquivo antes.
<?php
/* vim: set expandtab sw=4 ts=4 sts=4: */
 * phpMyAdmin sample configuration, you can use it as base for
 * manual configuration. For easier setup you can use setup/
 * All directives are explained in documentation in the doc/ folder
 * or at <http://docs.phpmyadmin.net/>.
 * @package PhpMyAdmin
 * This is needed for cookie based authentication to encrypt password in
 * cookie
$cfg['blowfish_secret'] = 'a8b7c6d'; /* YOU MUST FILL IN THIS FOR COOKIE AUTH! */
 * Servers configuration
$i = 0;
 * First server
$i++;
/* Authentication type */
$cfg['Servers'][$i]['auth_type'] = 'cookie';
/* Server parameters */
$cfg['Servers'][$i]['host'] = 'localhost';
$cfg['Servers'][$i]['connect_type'] = 'tcp';
$cfg['Servers'][$i]['compress'] = false;
/* Select mysql if your server does not have mysqli */
$cfg['Servers'][$i]['extension'] = 'mysqli';
$cfg['Servers'][$i]['AllowNoPassword'] = false;
 * phpMyAdmin configuration storage settings.
/* User used to manipulate with storage */
// $cfg['Servers'][$i]['controlhost'] = '';
// $cfg['Servers'][$i]['controluser'] = 'pma';
// $cfg['Servers'][$i]['controlpass'] = 'pmapass';
/* Storage database and tables */
// $cfg['Servers'][$i]['pmadb'] = 'phpmyadmin';
// $cfg['Servers'][$i]['bookmarktable'] = 'pma__bookmark';
// $cfg['Servers'][$i]['relation'] = 'pma__relation';
// $cfg['Servers'][$i]['table_info'] = 'pma__table_info';
// $cfg['Servers'][$i]['table_coords'] = 'pma__table_coords';
// $cfg['Servers'][$i]['pdf_pages'] = 'pma__pdf_pages';
// $cfg['Servers'][$i]['column_info'] = 'pma__column_info';
// $cfg['Servers'][$i]['history'] = 'pma__history';
// $cfg['Servers'][$i]['table_uiprefs'] = 'pma__table_uiprefs';
// $cfg['Servers'][$i]['tracking'] = 'pma__tracking';
// $cfg['Servers'][$i]['designer_coords'] = 'pma__designer_coords';
// $cfg['Servers'][$i]['userconfig'] = 'pma__userconfig';
// $cfg['Servers'][$i]['recent'] = 'pma__recent';
/* Contrib / Swekey authentication */
// $cfg['Servers'][$i]['auth_swekey_config'] = '/etc/swekey-pma.conf';
 * End of servers configuration
 * Directories for saving/loading files from server
$cfg['UploadDir'] = '';
$cfg['SaveDir'] = '';
 * Defines whether a user should be displayed a "show all (records)"
 * button in browse mode or not.
 * default = false
//$cfg['ShowAll'] = true;
 * Number of rows displayed when browsing a result set. If the result
 * set contains more rows, "Previous" and "Next".
 * default = 30
//$cfg['MaxRows'] = 50;
 * disallow editing of binary fields
 * valid values are:
 *   false    allow editing
 *   'blob'   allow editing except for BLOB fields
 *   'noblob' disallow editing except for BLOB fields
 *   'all'    disallow editing
 * default = blob
//$cfg['ProtectBinary'] = 'false';
 * Default language to use, if not browser-defined or user-defined
 * (you find all languages in the locale folder)
 * uncomment the desired line:
 * default = 'en'
//$cfg['DefaultLang'] = 'en';
//$cfg['DefaultLang'] = 'de';
 * default display direction (horizontal|vertical|horizontalflipped)
//$cfg['DefaultDisplay'] = 'vertical';
 * How many columns should be used for table display of a database?
 * (a value larger than 1 results in some information being hidden)
 * default = 1
//$cfg['PropertiesNumColumns'] = 2;
 * Set to true if you want DB-based query history.If false, this utilizes
 * JS-routines to display query history (lost by window close)
 * This requires configuration storage enabled, see above.
 * default = false
//$cfg['QueryHistoryDB'] = true;
 * When using DB-based query history, how many entries should be kept?
 * default = 25
//$cfg['QueryHistoryMax'] = 100;
 * You can find more configuration options in the documentation
 * in the doc/ folder or at <http://docs.phpmyadmin.net/>.
Olá,
Desculpa estar ressuscitando este tópico, mas acreditei que seria o melhor lugar.
Pessoal, instalei o CWP, consigo adicionar clientes, tudo....
Estou agora tentando configurar o e-mail, apanhando um pouco... Mas a minha dúvida é a seguinte, ex. uso o dominio.com configurado com o CWP (ou seja, dominio principal), como faço para poder configura-lo pelo CWP também? Ou seja, adicionar email, sub dominio, MySQL, etc...
